2025.1
Solved verification models.
View new features for SimSolid 2025.1.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Create an analysis for your project.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
The purpose and format of the SimSolid verification problems document.
Learn how to access and download required model files.
Test No. VT01 Find the temperature of the insulated end of a cooling fin surrounded by fluid with the other end maintained at constant temperature.
Test No. VT02 Find temperatures at firebrick and insulating brick surfaces in an insulated wall.
Test No. VT03 For a cylinder loaded with a prescribed heat flux, find the temperature at the boundary between where flux is applied and the rest of the side surface.
Test No. VT04 Find temperature at the mid-plane of a heat generating steel plate and the heat flow rate to the fluid the plate is heating.
Test No. VT05 Find the temperature at the centerline and surface of a heat generating wire.
Test No. VT06 Find temperature at points A, B, C, and D of an eight tube assembly.
Test No. VT07 Find the temperature on a plate with prescribed temperature and convection loads.
Test No. VT08 Find the temperature distribution on a beam subjected to transient thermal load.
Test No. VT09Calculate the average heat flux through a slab of thickness t (0.25 feet) within the temperature range (100°F and 300°F).
This section provides quick responses to typical and frequently asked questions regarding
